Wiring question
  • 3
Alright guys this is probably a dumb question, but I have a lot and I mean A lot of 12 or 14 guage speaker wire laying around. I'm getting an american bass xfl 12 in tommorow and I would like to make sure its getting at least 10 gauge wire. So I know this sounds ridiculous but can I just take the 12 or 14 gauge wire and twist the positive wire and negative wire together to make one thicker wire? Or would that not work for some reason? I hope I'm making sense about what i'm trying to do. Thanks.
you'll be more than fine with 12 gauge wire. no need complicate it. make it simple and just use 12 gauge - good to go
if you're really that paranoid yes you can twist it together and use two runs of the wire as one connection (i.e. positive, or negative)
it's parallel wiring at that point
Either will be fine. Only time I would double up on it or use thicker gauge is if your running multiple subs/amps and several 1000 watts.
Watch the video pop put up. Those don't put up anywhere near what they claim. Hence why spokey said run it at 1 ohm.
7
Just ignore Red...he's wealth of useless to dangerous advice...all without knowing what he's talking about
19
3K
Or a 25 and a 30, 25s are just harder to find in stores. I may be able to get one from my local audio installer. I already have to talk to them to...
6
nategearing42
vienna illinois
Boomin_tahoe
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
