Power switch wiring question
  • 2
txjeep
CarAudio.com Newbie
24
8
Texas
Next in my series of dumb questions:
2 amps, 1 under seat and one under center console about 18 inches away. Can I splice the two power signal wires by the amp and run a single wire to the head unit for power switch control?
I promise not to use wire nuts. :)
Some at DIYMA and other places have tried this Oscilloscope as well and got good results shockingly for such a cheap unit...
8
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
5
441
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
346
txjeep
CarAudio.com Newbie
txjeep
Texas
dragon.breath
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
