Wiring subwoofers with different ohm voice coils together
SkrillaPyles
CarAudio.com Newbie
I have a kenwood 9104d amp. I did some research on it and it says it does 900 rms at 2 ohms and is regulated down to a lil over 900 at 1 ohm .I had dual 12 punch p3s (2ohm) and wound up blowing 1 of them. my friend gave me a power acoustic gothic. It's a 4ohm dvc. I know it's not good to have subs that have different ohms. .. but since the amplifier is regulated at 1 ohm. So can I run the punch on left at 1 ohm and the gothic on the right at 2 ohm then they would be very close to receiving the same power
Thats a mono block amp. Its internally bridged with 4 outputs. All one channel. No left and right.
Running two different subwoofers causes cancelation issues let alone running two different resistance subwoofers. One will be getting more power than the other.
Yes I know that. How bout if I ran both speakers parallel. That you be 2+2+4+4=12 12÷2=6 then 6÷4=1.5 ohms, if the subs can withstand a 1 ohm load , how come I cant run a 1.5 ohm load?
It's doable, but they subs won't get the same amount of power. If your amp is stable down to 1 ohm, then it doesn't care how you get there; it only cares about the load it sees at the speaker terminals.
Having said that, I don't know where you came up with that formula for calculating parallel loads. If all parallel branches are the same resistance, you can use the formula Rt = Rx / Rn ; Total resistance equals the value of each branch divided by the number of parallel branches. If each branch is a different resistance, then you use the formula Rt = 1/(1/R1 + 1/R2 + 1/R3 ....).
In your case you could technically use either formula, but let's go with the latter:
Rt = 1/(1/4 + 1/4 + 1/2 + 1/2);
Rt = 1/(6/4);
Rt = 2/3 ohm, or roughly 0.67 ohm, which is lower than your amp can handle.
Your best bet would be to wire the dual 2-ohm sub in series to create a 4-ohm load, then wire all three 4-ohm loads in parallel. Thereby, Rt = 4/3 = 1.33 ohms.
As stated by others, having two different subs or sub with different impedances will not give you ideal results, acoustically speaking, but if you wire them correctly, it is far from impossible.
Bear in mind, I'm just some guy on the internet, as is everyone else who provides advice in forums. The information I gave you is electrically correct, but follow it at your own risk. If you didn't know how to calculate total resistance, you might be better off either keeping it simple (get two of the same subs) or paying someone to do it for you.
On a side note: I don't know how running two subs in phase with eachother would create any cancellation. I would love to hear the theory behind it.
Hope that helps.
- Joe
Rt = 1/(6/4);
Hope that helps.
- Joe
I know how to calculate the resistance if each voice coil is the same. But for some reason I was thinking you also had to divide it by # of subs as well then also using the wrong formula, I did not know how to do it with voice coils of seperate resistance. That's why I'm asking. I wasn't saying it like it was fact. I was asking a question about my math because it looked off and it was. as for the cancelation I was wondering about that too because I have already hooked them up in a parallel To my audiopipe ampi-1300. It didnt seem to have a problem with it. And sounded good
The different brands cause cancellation is real. It doesn’t happen in every case, but it does happen. It is basically because of a difference in response times of the cones.
Here is the over simplified version. Say you have two subs. One has a heavy cone, a 2 inch voice coil and a 30 oz magnet. And the second sub has a lighter cone, a 3 inch coil and a 100 oz magnet. Play a single drum beat. Sub 2 is going to move the cone quicker than sub 1. In fact, sub 2’s cone may be returning to rest while sub 1’s cone is still moving out. You end up with phase issues and cancellation.
Of course you can. The amp has no response to what is connected to it other than impedance. Wire the D2 in series for 4 on one output and the D4 parallel for 2 on the other. The p3 will see 1/3 of the power, the PA will see 2/3.
The amp doesn't have separate channels -- it's just two connections to the same channel so anything you connect to one output will be parallel to the other. Also -- subs don't "withstand" the load. They ARE the load.
Don't expect great sound quality, but it will give you some bass until you can get a proper matching pair.
You might have better results just running the Pwr Ac at 2 ohms.
I'm having a tough time with your logic here. I understand the theory you're running with. However, I would like to see an experiment with numbers to back that theory up.
Given the theory that cones move at different rates, they still have to react to the sine wave being delivered to the voice coil. If the cone reacts any fraction of a second behind the signal getting to its terminals, the cone will eventually either catch up with the signal or move in the complete wrong direction. I think it will catch up and move on-point with the signal. So that leaves a split second where they subs might be out of phase (unnoticably).
Also, given your theory is accurate, your two subs will always be a different distance from you, so you could argue that the different distances could actually make your subs sound louder by being ever-so-slightly out of phase. The sound waves/air vibrations have to travel from the speaker to any given point, so maybe the air vibrations would be more in sync by the time they get to the listener/meter.
Playing devil's advocate here, but I also don't like claims without facts to back them up.
Why not just go try it and see if you like it? Just use your knowledge and make your best educated guess. It might not be ideal, but it might work for now.
This isn't religion, there is no "theory."
We are talking pure FACT regarding cancellation. Overlay 2 different plots from a modeling program like Bass Box Pro and look at phase angle and group delay. The proof is in front of you- measured in degrees of angle and milliseconds.
This is absolutely theory until FACTS are presented. A modeling program isn't the same as real FACTS (since we are capitalizing that word for some reason). FACTS come from experiments, not simulation. Again, if there are any (proven,) facts, I'm genuinely interested in the subject. "Proven facts" is redundant, but apparently appropriate for the audience.
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
151
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
7
557
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
8
591
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
621
SkrillaPyles
CarAudio.com Newbie
SkrillaPyles
Decatur, tx
SkrillaPyles
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
