Wiring the audiopipe apd3000d to two dual four ohm subs
what do you want? 1 ohm? or 2? im pretty sure you cant get two out of dual 4's, but if you wire the subs in parallel, then parallel together, that will make 1 ohm. get duals 2's to get a final load of 2 ohms. audiopipes should be 1ohm stable.
The AP3000D is only stable down to 2 ohm. The 1500D will do 1ohm. FYI, the 3000D is just 2 1500Ds strapped inside one case.
in which case the OP has to wire in series and present amp with a final 4ohm load
and no, you cant get 2 out of 2 4ohm dvcs on a mono amp. You can on a 2channel tho by wiring a 2ohm stereo load
this....dont take advice from
wait a minute, that amp is 1 ohm stable....only with 2 channel though right.......
2 channel = 1500w at 1 ohms
1 channel = 3000w at 2 ohms
correct me if im wrong but couldn't the OP just wire EACH sub at 2 ohms and go 2 cannel...he would probably get around 1000w to each sub
2 channel = 1000w? at 2 ohms
Deff need to lnow what subs.. Make and Model# would help quite a bit. What amplifier will you be using?
101
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
362
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
354
Box rise, more accurately, impedance rise, is the reactive load changes the woofer exhibits at different frequencies and it will happen, it's...
4
667
ken2516
ken2516
albany ga
Deeper_shades
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
