Wiring the audiopipe apd3000d to two dual four ohm subs
what do you want? 1 ohm? or 2? im pretty sure you cant get two out of dual 4's, but if you wire the subs in parallel, then parallel together, that will make 1 ohm. get duals 2's to get a final load of 2 ohms. audiopipes should be 1ohm stable.
The AP3000D is only stable down to 2 ohm. The 1500D will do 1ohm. FYI, the 3000D is just 2 1500Ds strapped inside one case.
in which case the OP has to wire in series and present amp with a final 4ohm load
and no, you cant get 2 out of 2 4ohm dvcs on a mono amp. You can on a 2channel tho by wiring a 2ohm stereo load
this....dont take advice from
wait a minute, that amp is 1 ohm stable....only with 2 channel though right.......
2 channel = 1500w at 1 ohms
1 channel = 3000w at 2 ohms
correct me if im wrong but couldn't the OP just wire EACH sub at 2 ohms and go 2 cannel...he would probably get around 1000w to each sub
2 channel = 1000w? at 2 ohms
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
186
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
590
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
626
642
551
ken2516
ken2516
albany ga
Deeper_shades
