SOLD WTT: DLS Ultimate A6 w/ bass knob for JL Audio 1000/1
spark plugs.
i know it sounds stupid, but this is what i'm trying to do. The amp is in mint condition and plays great. i could probably even dig up the manual for it if necessary.
Number of channels 1
Amplifier class AB
Output power in 4 ohm 500 W
Output power in 2 ohm 870 W
Mono bridge mode 4 ohm N/A
Output power in 1 ohm 1200 W
Damping factor> 200
S/N ratio, A-weighted > 100 dB
Frequency range 10 Hz - 125 Hz
Input sensitivity 0,2 - 7 V
Input impedance, high level N/A
Input impedance> 10 k ohm
High pass filter Subsonic: 25 Hz
Low pass filter 50-125 Hz
External cooling fan terminal 1
Dual DC inputs 1
Remote base level control 1
Remote phase shift control 1
Integrated fan 1
Power consumption (idle) 0,6 A
Power consumption (max) 140 AR
ec. power cable Minimum 2 AWG / 33 mm2
Fuses 4 x 35 A
Dimension (W x D x H) 410 x 240 x 73 mm (16,15 x 9,45 x 2,87 inch)
Weight 6,2 kg ( 13,67 lb)
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
spark plugs.
spark plugs.
New York, NY
franz777000
