SOLD WTT: DLS Ultimate A6 w/ bass knob for JL Audio 1000/1
spark plugs.
i know it sounds stupid, but this is what i'm trying to do. The amp is in mint condition and plays great. i could probably even dig up the manual for it if necessary.
Number of channels 1
Amplifier class AB
Output power in 4 ohm 500 W
Output power in 2 ohm 870 W
Mono bridge mode 4 ohm N/A
Output power in 1 ohm 1200 W
Damping factor> 200
S/N ratio, A-weighted > 100 dB
Frequency range 10 Hz - 125 Hz
Input sensitivity 0,2 - 7 V
Input impedance, high level N/A
Input impedance> 10 k ohm
High pass filter Subsonic: 25 Hz
Low pass filter 50-125 Hz
External cooling fan terminal 1
Dual DC inputs 1
Remote base level control 1
Remote phase shift control 1
Integrated fan 1
Power consumption (idle) 0,6 A
Power consumption (max) 140 AR
ec. power cable Minimum 2 AWG / 33 mm2
Fuses 4 x 35 A
Dimension (W x D x H) 410 x 240 x 73 mm (16,15 x 9,45 x 2,87 inch)
Weight 6,2 kg ( 13,67 lb)
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
spark plugs.
spark plugs.
New York, NY
franz777000
maylar
    Jun 2, 2024
    Jun 1, 2024
