XS 14V CHARGER...HF1415 Intellicharger
  • 1
I have this one as well and it has been very useful. Would recommend if you need a versatile battery charger/small power supply.
Did you consider using the PAC AmpPRO 4, AP4-CH31? It will connect between factory amp and head unit and allow you to have RCA outputs for the amps.
Do you have about $100 to waste? Try a cheap amp that has line-level inputs, see if that helps. WalMart carries a 4 Channel Jensen amp, for its...
bigdhenderson
bigdhenderson
North Iowa
bigdhenderson
Decebal
    Jun 10, 2024
