Xtant A6001 Mono
gentlejax
Item(s) for Sale:Xtant a6001
Item(s) Description/Condition:good , some scratches but fully functional
Price:$150 shipped
bear in mind its recomended you use an 80 amp fuse for it and it is class D
Specs:Frequency Response: 20 Hz to 120 Hz +/– 1 dB
Number of Channels: 1
Watts per Channel @ 4Ω: 1 x 300
Watts per Channel @ 2Ω: 1 x 600
Recommended Load: ≥2Ω
Distortion (THD): ≤2%
Measured: 20 Hz to 120 Hz at rated power, all channels driven 4Ω
Signal to Noise Ratio: ≥ 100 dB
Measured: A-weighted in 20 kHz noise bandwidth @ 1 volt sensitivity
Damping Factor: ≥ 100 @ 100 Hz with 4Ω load
Input Sensitivity: 100 mV to 8.5 V RMS Unbalanced
200 mV to 17 V RMS Balanced
Input to Line Output Gain: 0 dB
On-Board Crossover: 24 dB/Octave Low Pass
Balanced Line: On Board
Power Supply: Fully Regulated, PWM
Operational Voltage: 10 to 16 Volts
Fusing Requirement: 40 Amp
Size (L xW x H): 11-5/8” x 9-1/4” x 1-7/8”
295mm x 235mm x 47mm
Subsonic Filter: 24 dB/Octave 20-80 Hz
Bass Boost: 0-12 dB @ 45 Hz
^ Those specs are for the a3001
Here Is the rated specs..
$140 shipped. if you have a 2ohm load this amp will rock. unfortunately I have 2 subs and neither of them are 2 ohm. I have a perfect amp for my sub lined up so this needs to go.
  • Locked
COMPLETED Xtant XIS 2.4
Also looking for the crossovers
  • Locked
793
I get it. I'd never run a tone through at full tilt to test just how much they can take before it goes all willie nelson either 🤣
72
5K
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
gentlejax
gentlejax
Bossier City, La.
gentlejax
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
