Y splitter wierdness
  • 2
GraphicHealer
CarAudio.com Newbie
Hello there, i have been having this wierd issue.
Here is my car setup:
Raspberry pi computer
DVD player         |
            \ Splitter /
FM modulater behind headunit
What is the wierd part about this is the fact that when I turn the DVD player on, the raspberry pi works. When I turn the DVD player off, the sound cuts out. What the heck? The pi and DVD player aren't even connected. The only connection made is the splitter. That's it.
Any ideas of the issue?
Thanks,
G
A splitter isn't the right way to toggle between two audio sources.
You must understand that all the connections are in parallel, and as such you're changing the overall perceived resistance that the FM modulator sees
If you use the crossover in the head unit, then you aren't sending that part of the signal to the amp. (Whether or not that allows a more narrow...
978
This option is better because you need 3 pairs of RCA cables. Tweeters, midrange, and bass. You then use a Y at the amps on the Bass run, then use...
8
3K
GraphicHealer
CarAudio.com Newbie
GraphicHealer
GraphicHealer
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
