specialnupe
Number of subs preferred: 1
Size preferred (if configuration allows): 12"
could do (2) 10's in a sealed or (1)12" in a ported. Because of space.
Budget:
Say around $500ish
Power to be used (which amp(s), include which resistance):
I have a huge 6 channel OLD SCHOOL FULTRON BELLE. plan to use the sub channels to power the sub.
Sub channel is
2 x 150 @4 ohms
1 x 300 @4 ohms
1 x 600 @2 ohms
1 x 1100@1 ohm
Space available (take measurements, do not guess): I got enough for 2cubes and some change.
trunk of 2011 BMW 328i Sedan.
Goals:
I want more bottom end, good clean bass that can play low notes. I'm not going for SPL.
Keep in mind I have the BMW LOGIC 7 system. I will be just "adding" to the stock system.
Listening habits: Rap, R&B, EDM
Preferred brands/subs/whatever:
I aint bought a dang car sub since 2006. Been rocking my cheap pioneer 10's in a vented box.. since then on a cheap Kole audio amp. In different cars I've owned since then.
Sundown SA-12 seems to be what everyone is jerking off to these days...so I guess I'll get in the circle... unless someone has another interesting option.
A little more info:
Just got the Bimmer... so it has a NICE stock system. It just doesn't have the bottom end I LIKE.
I will need to use a line out converter to tap into the stock wiring.
I have ENOUGH power to push a good range so subs on the market.
Budget:
Say around $500ish
Sub channel is
2 x 150 @4 ohms
1 x 300 @4 ohms
1 x 600 @2 ohms
1 x 1100@1 ohm
Goals:
A little more info:
