Zed Audio Minotaur I Repair
It's been to him twice and still has had the same issue after getting it back. Long story short, we had a "disagreement" awhile back and he refused to repair anything for me anymore. Then, I sent it to another well-known repair technician/engineer that used to work with him and he couldn't fix it either after having it for a year (at least he told me that he couldn't). I just want the amp fixed so I can either use it or sell it. This post isn't meant to throw spears at anyone.
If you are planning on selling it, just throw it on eBay the way it is. Fully describe the problem with it. Their are people who repair amplifiers as a hobby who will buy it as a challenge.
I sold a broken Rockford amplifier on there a couple of years ago, the difference in price was less than the repair cost would have been.
If Stephen couldn't manage to get it working I can't imagine who else can.
That said, not sure if Sound West in Tacoma does amp repair beyond Harmon International products but they have a guy there that can fix A6000GTI amp which by all accounts is an overcomplicated nightmare so I'd imagine if that guy still works for them he is pretty damned good at amp repair.
I finally got the popping issue fixed but now there's loud static when I use the amp's crossover (high/low) in "Pre" mode. If I put it in "Flat" mode, there's no static noise. I swapped out RCAs and it still has static. I swapped the amp out with another Minotaur amp and there wasn't any static noise in "Pre" mode. What could this be?
It could be dirty pots. I assume flat mode bypasses x-overs so no need to run signal by the pots.
Yes, "Flat" mode bypasses the amp's x-overs. I just got it back from being repaired so I would've hoped it was fully checked out and tested prior to them returning it. I guess I'll just have to use the H/U's x-overs and run it that way.
I hear Mike Nicholls at US Acoustics is very good at repairing amps. He was at Zed in their early days. Maybe give him a shot, that is if he will do the repair.
He was the "well-known repair technician/engineer that used to work with Zed" that I sent it to but he couldn't fix it. The continuous popping noise has been fixed after I sent it to someone else for repair but now it has loud static if I use the amp's x-overs.
try replacing the RCA inputs on the amp`s board itself,requires that the inputs be desoldered from the main board and replaced with new ones.
  • Locked
I don't suppose you have a spare Zed mikro IV in your collection? I'm conveniently located in central Florida and have cash on hand, lol. Matt
6
3K
The siq amps are Sq beast as well. And much cheaper. Made by s&I in Korea iirc
125
Ill check it out. I was actually on the site last week. Thanks!
279
firey_kimchi
firey_kimchi
Misawa AB, Japan
jrouter76
slater
    May 2, 2024
slater
    May 2, 2024
Latest topics
