Not sure you are going find anything smaller that I can think of. Width wise and lengthI’ve got this one and it’s too big
This is why I don’t trust Amazon specs
- Package Dimension : 36.0 inches L x 34.0 inches W x 24.0 inches H
There’s a module right thereCould you use an L-bracket and tape or screw it under the lip? The fuses facing the amps would be the best orientation.
Im looking at this pic thinking id look at raising those amps upward right at the lower portion of the(- connection of the sub wire connection and place it under the amplifiers. id move the shorter amp in the large amp location. all speaker wiring on the top areas and the power and grounds and remote @ the under area of the amps. would be plenty of room then. all speaker wiring can be zip tied neatly at the top. Thats me thoughCould you use an L-bracket and tape or screw it under the lip? The fuses facing the amps would be the best orientation.
Like a platform. That is a good idea. Looks like plenty of height as well.the top areas and the power and grounds and remote @ the under area of the amps
Damned good idea. I could raise them 2” and have plenty of room.Im looking at this pic thinking id look at raising those amps upward right at the lower portion of the(- connection of the sub wire connection and place it under the amplifiers. id move the shorter amp in the large amp location. all speaker wiring on the top areas and the power and grounds and remote @ the under area of the amps. would be plenty of room then. all speaker wiring can be zip tied neatly at the top. Thats me though
Man. I think so. The small 4-(2) 8 ga mini anl fuse holder should be able to fit just under the smaller amp after raised and mount to the wall just fine and supply both amps with a short power supply run from the anl fuse holder... less than a ft of supply wiring maybe??> daisy the remote from amp to amp too. I would think that smaller amp would be the sub amp? not sure but sub speaker wiring would be short too and nice and snugg/clean.Like a platform. That is a good idea. Looks like plenty of height as well.
Nice price on that man. Fuses included. Sweet!!Damned good idea. I could raise them 2” and have plenty of room.
I just bought these today
They should be here by the weekend![]()
Fuse Distribution Block 2 Way 4 to 8 Gauge Out
Buy 2 Way Mini-ANL 4 to 8 Gauge Output Fuse Distribution Block. KnuKonceptz Includes Your Choice of Fuses Ranging from 20A to 150A with Purchasewww.knukonceptz.com
Smaller amp is the 200.4Man. I think so. The small 4-(2) 8 ga mini anl fuse holder should be able to fit just under the smaller amp after raised and mount to the wall just fine and supply both amps with a short power supply run from the anl fuse holder... less than a ft of supply wiring maybe??> daisy the remote from amp to amp too. I would think that smaller amp would be the sub amp? not sure but sub speaker wiring would be short too and nice and snugg/clean.Thats what Im looking at? Its not my ride though,LOL
I was just looking at those .. LolSmaller amp is the 200.4
Bigger amp is the mono
Id run what you have. Give it a chance/try to incorporate what you have. No since in spending funds on other gear without giving it a run/try? Thats me though. you can always change and or try other gear later. I like a dedicated sub amp and mids and highs amp myself.Should I just sell the Kicker Keys and get a damn 5 channel. That way I don’t have to worry about distribution
