sub + amp
  1. ChasingTimez
    COMPLETED pretty much new Memphis mojo 8" single with RF Punch P1000X1bd
    i got into a few car accidents this year and my insurance is no longer payable and i would rather not drive and save my money and also been needed to sell my car so my amp and sub is no longer needed im looking to get $800 at most and $600 at lowest. i also have the original box for the amp but...
  2. jparker3207
    I know you get a lot of these but best budget subwoofer + amp under $500-600
    I have a 2018 civic hatchback so the trunk is connected to the main cabin. I got around $600 i can spend and can only really push it another hundred. i want to get a good subwoofer and amp that’s gonna be loud but id like it to be standard quality. I saw the Scar 12” sdr kit but have heard mixed...
  3. J
    Amp problem?
    I have an amp and subs in my car. The amp power light blinks and subs stop working and it goes in and out when music is played. I made sure all the connections were solid, Checked fuses. Not sure where to go from here! Any recommendations?
  4. B
    Need help with the design of my sub and amp system
    I came to a conclusion that i need to install a sub in my car(Ford Cougar 1999 or in USA Mercury Cougar) as of right now i have an aftermarket head unit and speakers. The head unit is Kenwood kmm-bt205 and the speakers are 4 Hertz speakers and 2 tweeters (I don't know any details about them...
  5. ryanpowell41
    Help with my alpine type r10s 500rms
    So I have a pair of alpine type r 10s the grey ones 500watt rms 1000watt rms to both they are the dual 4ohm. I want to get max power I can with my amp I have and I’m not sure how I wire them to my amp and in the box.it’s a CT Sounds CT-1000.1D Compact Class D Car Audio Monoblock Amplifier, 1000...
  6. C
    COMPLETED FS: Car Audio Lot Amps/Speaker/Subs
    Use to be active a lot on this site, been a while and had to create a new account because I lost my info. Selling multiple items Massive Audio 84 subwoofers $80/$60 (have some cosmetic wear) Hifonics ZRX3000.1D $200 (Like New) Focal 165A1 components $180 (New) Infinity Kapp 10.11t Tweeters...
  7. Jace14
    Can i just connect my mid to high speakers to my radio?
    Hey guys, so im making my first build on a old 1988 toyota 4runner and im installing some new Pioneer 250w mids and highs with a Magnat ultra 300 Reflex subwoof and a Magant rock 4000 amp. Because english isnt my first language its a bit hard for me to understand all of the tutorials so i just...
  8. C
    2 DVC 4 ohm to mono block 1 ohm
    Picked up 2 12" Pioneer TS-A300D4 4-ohm DVC subs with 500W RMS n 1500W Peak. Got a KAC-9105D amp. What's gonna be the optimal way to wire these? Manual says RMS 500W per channel @ 4-ohms, or 900W @ 1-ohms stable (output regulated to 900 watts). Amp is mono but has 2 outputs that are internally...
  9. T
    Sub keeps going out. Why?
    I have a 2015 Audi A5 coupe that was taken to a an audio shop back in 2019 to get subs installed. At this time, I had bought a Skar audio package online, it had 2 8in subs, the wiring kit, and a 1200w amp. It was my first sound system, so I just got what my friends had. The 2 8’s lasted for...
  10. HughBushor
    HELP My Amplifer Went into protect mode and I can no longer hear my sub
    I will be the first to admit I am not familiar with any of this but I had bought a 1200 watt 12” bundle from skar over a year ago and had the intentions of putting it in with a buddy long story short a year later I decided to get it done by a professional because we made no progress, $400 later...
  11. R
    No sound after blowing radio fuse
    Hey guys, I have a 1 sub, 2 speaker set up running off an aftermarket head unit and amp. Everything was working great for a few weeks. The other day I unplugged the head unit and accidentally sparked the main power wire when it touched some metal in the dash. This blew the radio fuse under the...
  12. H
    Urgent
    I was running a test tone and put my DMM AND as soon as the test leads made contact to the speaker outputs it’s sparked and my amp switched into protect mode for 10 seconds thoughts? Is it safe?
  13. SKINNYNIPPLES
    Wiring 2 JL subs ho boxs to one amp
    I have this amp https://www.crutchfield.com/p_13698617/JL-Audio-RD1000-1.html And two of these subs in box https://www.crutchfield.com/p_13693310/JL-Audio-HO110-W6v3.html From website "The woofer's dual 4Ω voice coils are internally wired in parallel to present a 2Ω load. Terminal: The...
  14. G
    Anyone ever used these?????
    I just stepped up my bass game an bought this combo. Can anyone please help I can't find a review on these for anything. Just curious what kind of performance I can expect.
  15. D4LL4S_85
    Sun cutting out….
    Okay, first off thanks for taking a few mins to read and possibly help me out… ok so I have 2 fosgate p2s 12s on my 05 Silverado and a 600.1 mono block alpine amp …bought a sundown v2 10 but think I got ripped off on that one …anyways. So I installed my system and when I turn it up to high...
  16. N
    I have tons of tiny questions if someone is willing to answer
    I plan on purchasing a U-12 1500w D2 Sundown and Cab-22 2200w AMP. Any problems with these?(Stock Electrical Sys)(Aftermarket Radio)(Already have all the wiring setup) How do I wire it to 1 OHM(someone on reddit told me that) I dont understand OHMs yet. What is Bridging and will I need to use...
  17. B
    Need help asap subwoofer problems
    Hello I have two 4000w subs with a 1 inch box Also i have a smart 3 taramp 3000w amp With 4gauge wire. Amp keeps going into protection and turns right back on after certain volume they hit hard untill i push the volume to high??? Plz help do i need 0gauge wire or another amp
  18. D
    COMPLETED JL Audio Subs & Amps in Ported Enclosure
    -Two JL Audio 12W7AE-3 Subwoofer Drivers -Two JL Audio HD750/1 Monoblock Class D Wide-Range Amplifiers -One HD600/4 Four Channel Class D Full-Range Amplifier These five items were bought from JL Audio for $4,689.95 plus tax. The ported enclosure was customized to fit in my Jeep Wrangler...
  19. J
    COMPLETED Like New - JL Audio XD 10005v2 Amp & JL Audio W6v3 in High Output Box
    *One 12 inch W6v3 in a high output box, and one JL Audio XD 10005v2 amp* Purchased in March of last year. Amp powered the sub and 4 focal interiors (original receipt for sub and amp available). I purchased them and had them installed in my Lexus by a local car audio shop. I'm now looking to...
  20. S
    Sub doesn't play when my car is moving
    I recently installed a sub and amp into my sister's car, its a 2002 Chevy blazer it has a stock stereo. I installed a line output converter because there were no RCA connections and I wired the remote wire to a wire that said it was 12v on a website's wiring diagram (I can post it if needed)...
  21. N
    LPF
    Hey all, I am kinda new to the technical things of car audio. I recently put 4 10” R2D4 rockfords running out at 2 ohms in a sealed box to a JBL A1000 amp. I’m curious as where I should set my LPF. I have my gain set at about 44 volts. The subs frequency response are 45-250 hz with sensitivity...
  22. G
    Subs making noise, help
    I wired up a sub and amp about a year ago and everything worked fine. Something happened and my sub stopped working. I bought a new amp and sub thinking either could be the problem. I never changed any of the wiring. Everything is still the same besides the amp amd sub. I started up my car and...
  23. npal_77
    Sub amp issues
    Hey everyone, So I just recently switched my sub and amp to a car I just bought. It's a 05 Acura TL, which has a stereo that's difficult to remove and retain all channels/speakers. I tapped the stock subwoofer remote wire, ran that and my power to the back, tapped the stock sub's signal and ran...
  24. Jeano221
    Subs amp going into protection mode after turning it up HELP
    So I’m having a issue with my amp going into protection mode after turning the radio up, it’s a stock bmw radio and the positive and ground are 11.90 when cars off and 13.60 when car is on, I switched amp snd still did the same thing... don’t know what else to check. Do if anyone can Help me out...
  25. S
    Are 3 12” sub setups good or just a weird gimmick
    I was trying to find some info about 3 12” sub boxes and setups but I couldn’t find much info on if they are good or just a waste of money. I want to slowly upgrade my car audio system and one of my main concerns is that I listen to a lot of different music that is mastered very differently...
  26. N
    Skar vs Rockford
    putting some subs in my girlfriends car, she doesnt want anything too crazy so im debating on getting her either 2 p3 12’s or 2 skar vxf 12’s. also need an amp suggestion for the subs. thank u
  27. Maddog456
    Old setup going into newer car. Need new amp?
    Ive had this build for a while now. 2 MTX JackHammer JH4512-04 12" 4-ohm subwoofer and a Pioneer 800w GM-7300M Mono subwoofer amplifier 360 watts RMS x 1 at 2 ohms. I was told to get this by some people so thought it was good at the time and for my wallet. I put it in a 02 focus had some...
  28. J
    Need some help picking out a sub and amp setup
    So currently I'm looking to put a sub in my 350z, I came across a photo that shows how to make a sub box that fits perfect. It only provides about .64 cubic feet so finding a sub is hard, I found this skar sub (https://www.skaraudio.com/products/svr-8-inch-800-watt-max-power-car-subwoofer) which...
  29. Jgrif593
    Monoblock Amp with Two Sets of Terminals wired Parallel
    I have a Skar RP-800.1D, it is a monoblock with 2 sets of speaker terminals. I know that this is for easier wiring/ more space for wires. My question is when I wire this into my DVC sub, can I just run + to +, + to +, - to -, and - to -, and would this end up as parallel wiring? -For any...
  30. G
    Combining Power for Amps
    I am planning out my install and want to run a single power cable from the battery to the trunk, then split into two 4 gauge cables to power a sub amp and a speaker amp. Each are rated for 4 gauge power. My thought is to use a larger fuse at the battery and then 2 individual fuses at the split...
  31. AccordExL2k15
    Remote wire problem Accord 2015 ex-l navi coupe
    Hey, I just installed a pre-amplified sub to the OEM sound system. The huge problem is that I can't find a good source for my remote wire. I tried taping into the rear speaker wire (this has worked on my 09 Yaris and 08 CSX-S) but it doesn't seem to work here. I then ran the remote cable to the...
  32. B
    amp question/help
    Hey everyone Im a “noobie “ to the car audio world. I have a 2011 Corolla & Google says my stock alternator runs 100 amps. Would that be enough to run an all in one enclosure sub/amp.? or am I looking at needing upgrade my alternator.? 800w Maximum Power RMS: 200 Watts Impedance: 2 Ohm
  33. Busyb318
    Need help with subwoofer and amp wiring
    I just installed two DS18 genx 12 inch subwoofers and a DS18 candy mini monoblock amp. The subs are dual 4 ohm rated at 450 rms each I have them wired at a 1ohtm load at amp which is rated at 1000 watt rms 1 ohm or at 450 rms at 4ohm. For two days it has been sounding good . Now it when I...
  34. R
    Small Off Grid Sound System 12V
    I want to upgrade my jbl Partybox 300, which is a battery powered boombox by adding an aditional subwoofer. Would it be possible to hook up a Sub and Amp directly to a car battery? I was thinking of purchasing second hand one, something like the Edge EDB10A-E2, it has a built in amp, which is...
  35. mrpep
    Taramps and mofo sub
    So I bought a mofo 104x cause it’s 1200 rms and I threw a taramps he 3000 amp at it, running this at 2ohms and the amp should be able to put out like 1500 rms at 2ohms. So I have the sub in a ported and it’s not as loud as I expected. I start clipping so it’s pushing the power out so I back off...
  36. I
    No audio out of stock speakers when sub is on?
    Hello, I have a 2006 Honda Civic, running a Boss R110m amp with 2 8ohm subs in series, using a PAC-SNI 35 LOC, with stock head unit. I have the amp powered getting the remote turn on wire from a fuse in the fuse box, and I will be hooking it up to the proper wire soon, but for now it powers on...
  37. D
    Too Much Power to Subs?
    I recently purchased a Crescendo BC3500D. I have 2 American Bass XFL 12's rated at 1000rms and 2000 Peak. My plan was to wire them up as shown here https://images.crutchfieldonline.com/ca/learningcenter/car/subwoofer_wiring/2-DVC-4-ohm-mono-low-imp.jpg But that would mean 3875 watts rms from...
  38. D
    Please help with all possible outcomes and solutions
    Ok, i have a problem with my amp going into protect mode if i hook up more than my 2 12s and i need to know what wiring method to use and what to hook up.... i have a 1200watt 4ohm bridgeable ssl amp, 2 300 rms max 4ohm dual 12s, 2 300 rms max 4ohm mtx audio 10s, and 2 300 rms max 4ohm kicker...
  39. I
    Help finding everything i would need for this setup.
    Hello, i am new to car audio so i don't know that much yet but im going to be getting 4 sundown SA series 12"s and wondering what i would need to power it all. I was looking at the Crescendo Audio BC3500D for the amp so 3500w power, would i need a new alternator? new battery i have no idea i...
  40. S
    Dual 10" sub build in floor of trunk in replace of spare tire
    So im looking to rebuild the floor of my trunk and have two 10" subs, amp and capacitor installed in the floor of the trunk but I need help/ideas for how I would be able to really build it as in framing. I own a 2005 mazda 3 hatchback and im looking to hopefully have two 10" subs amp and...
