Wiring 2 JL subs ho boxs to one amp
  • 5
SKINNYNIPPLES
CarAudio.com Newbie
5
MO
I have this amp https://www.crutchfield.com/p_13698617/JL-Audio-RD1000-1.html
And two of these subs in box
From website
"The woofer's dual 4Ω voice coils are internally wired in parallel to present a 2Ω load.
Terminal: The enclosure features a pair of 5-way binding posts; they will accept pin connectors, spade connectors, single banana plugs, dual banana plugs (standard 3/4" width), and bare wire up to 10 gauge"
I'm sure messing with the sub wiring will void warranty .
Do I just run two amps ?
How would I wire these seperate subs boxs to this amp?
Says 2 ohm impedance
You have 2 boxes that have speaker out puts each box is 2 ohm( if I'm correct). run wires from each box and put the positive to the positive and negative to the negative from each box the put them into the amp that will give you a 1 ohm load
I wouldn't buy another Amplifier if I did I'd run a completely different one that was 1 ohm stable There's plenty of cheaper stronger amps that can run that setup. I know people love jl and they want to run the subs with the amps but for the same price of a rd 1000 I can name a few amps that will get the job done and have you more than satisfied with the out come. Also I have ran several jl setups so I'm not just talking out of my a$$
Sell the JL
Sell the JL
Strong American amp with good customer service and trch support I forgot about mmats
Wire to the 2ohm diagram as shown for the MTX subs on the one amplifier you have. That amp should do very well on those two subs. alpine make some...
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
Sure, 600 volts, yep. If you’re trying to launch the subwoofer cones to the moon! And, that’s if they don’t just vaporize first!
34
4K
Sell the dual 2 and get another dual 4.
SKINNYNIPPLES
CarAudio.com Newbie
SKINNYNIPPLES
MO
KicktheSDbasshead
Doxquzme
    May 22, 2024
1aespinoza
    May 22, 2024
