Deck turns on, plays no sound anymore
  • 2
sizzl3r
Minnesota
I was installing a new deck (some cheap Dual from Walmart)into my friends 2001 suburban last night. After I got all of the wires spliced together, I plugged in the deck real quick just to make sure it was working. It played music just fine, and his subs/amp turned on and were working. So I unplugged the deck to assemble the dash kit, and when I put it in the 2nd time and turned it on, no sound came out. I thought maybe a wire came loose but when I pulled it out, everything was in tact.
I fiddled around with the deck but couldn't get sound to come out. I assumed it was probably a bad deck since he bought the cheapest one he could find. So my friend took it back to the store and some how managed to return it and get his money back in exchange for a JVC deck. We took it back, wired everything up, plugged it in to test it, it worked 100%, unplugged to put it in the dash and when we turn it on, it doesn't play sound. Seriously, what's going on? This can't be 2 bad decks in a row. I really need help on this one, my friend is pissed that he spent all this money on this and it's not working. Thanks
Sounds like you are having a wiring issue to me. I would assume best case, it is a stock amplified system and your remote wire is coming loose during removal and installation. Worse case, you have poor connections to the point something is arcing out or touching during installation that shouldn't be and you are damaging units.
Nothing like this "just happens". There is always a cause.
His car did have somewhat of a stock system. The suburbans had an 8'' factory sub in the back. He had subs installed without taking out the factory deck. Is there is an issue here? I highly doubt it's the wiring. Connections were secure and showing no wire.
WANTED Cassette deck
I have been but I trust people on the forums a lot more.
286
Search Amazon for the Dual DCPA701W I had it for about a year and it sounded and worked flawlessly. It was very clean sounding, especially for a...
16
appriecate it man! I was so busy thinking about it that I didn't even think I could look it up with a multimeter.
5
With the remote wire out. Make a jumper from the amp's power to the amp's remote terminal. If it turns on then the amp is ok. If not then the amp...
776
sizzl3r
sizzl3r
Minnesota
sizzl3r
winkychevelle
    Jun 3, 2024
