help me understand
  • 2
subs normally list displacement which is what you need to subtract
the port depends on aeroport or square port
bracing depends on what type of bracing there are lots of styles, 45's in corner, round dowels, threaded rod, picture frame, ect...
Most of it is math. the total box is pretty simple, L x W x H. Then you have to figure the internal.
Here's my example:
Largest box that fits through my trunk opening is 29.5" x 17" x 16.5 external. So the internal is 1.5" less of each of those dimensions(2 sheets of 3/4" wood), so 28" x 15.5" x 15"= 6510 cubic inches.
Since we all use cubic feet which is 12x12x12=1728.
So I divide my 6510/1728=~3.76cubes
My SA12's are .14 each so .28
my 6" aero is pi x r^2(times the length gives volume), radius is r and equal to 1/2 the diameter. The external dimension of the port is what you need, so ~6.3" which/2=3.15". 3.15^2 x pi(3.14159)= 31.17 now times the length of 17" = ~530 cubic inches divide by 1728=.306
I also have bracing using 1" dowel with 15.5 length and another 15" length, so add together 30.5. Using the same formula as above, 1/2=.5, .5^2 x pi x 30.5=~24 cubic inches divide by 1728=.013 cubic feet
so if I take all the displacements, .013+.28+.306=.599 cubic feet
so 3.76-.599=3.16 cubes after displacements
For the Aero port I fudge it a little since I dont know how to get the true displacement of the internal flared end.
Thats the idea, my box will end up a little bigger with some tricks up my sleeve and maybe inverting the subs
40-85l is about the size range most high powered 12" woofers will want for a box. You should use manufacturer suggested box specs unless someone...
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
188
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
462
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
453
Lschevelle
Lschevelle
LA.
SpeedEuphoria
