HELP?? to isolator or not to isolator
  • 2
Joe562MMA
ok i been deciding weather or not to run an isolator for when i install my 2 back batteries i heared isolators are usless ..
then i heard that i can run a isolator relay,,which just looks like a solenoid to me any help would be appreciated..
im running a 235 h/o alt//
one yellow top optima in front
an i plan on running too UPS 12-370FR c&d batteries in the back
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
332
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
500
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
503
Joe562MMA
Joe562MMA
Los Angeles , CA
mclerico83
Dylan27
    Jun 5, 2024
HandsomeSteve
    Jun 5, 2024
