Help with German Maestro SV 6509s
  • 2
justncredible
I have a front and rear set of German Maestro sv6509s that i had installed and for some reason i just cannot get them to sound right. they sound hollow and lifeless and tooo high pitched. are there any suggestions on what i should do to find out how to fix it? adjust amp headunit dynamat doors etc?
could be phase issues.
what vehicle?
what headunit?
how wired (new or factory)?
1. if some are out of phase with others they will sound weird.
2. if you didn't adequately seal the openings and speakers they will sound hollow. i use weatherstripping foam on front and back of each speaker to seal against the door panel and door metal, respectively.
3. head unit amplifiers are small and low power. external amps are key, but only after the above are resolved.
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
182
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
459
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
446
justncredible
justncredible
Redlands
keep_hope_alive
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
