Mounting MDF rings to sheet metal, (with minimal access to behind).
  • 4
I am going to mount some components to my factory C pillars. It's on a pickup and the factory speaker is a 4 x6". The sheet metal has about a 2" gap between where it will mount and the outer body metal. I'm going to do a slight trim on the raised surface, and install a 6.5" midrange their. I think I have how I want to do it, but wondering if someone had something to offer.
I have a precut MDF ring that I am going to mount to the sheet metal to raise the mounting surface. I've done something similar for subs in a custom box, but my plan is:
- Mount the speakers to the mdf ring so I know where the holes are going to mount, and mark the ring so I can keep the angle correct.
- Drill holes between my speaker mounting holes through the ring, and drill through the sheet metal.
- Then I drill a second hole a little bigger in the mdf as deep as the t-nuts and mount t-nuts on the outside face of the rings, pulling them flush and using a clamp if need to so they sit level or as close as I can (under where the speaker will mount).
- From the backside I feed a button head bolt with washer, (and between the washer to sheet metal I add a little deadener). I will have to figure out the right length bolt to buy or cut so it sits just below the top of the T-nut. I don't have the room to fit a 90 degree/slim bit driver. ( I might even have to feed them all in, and slowly tighten them together). What I do is dremel cut a groove into the flat thread end of the bolt. That way I can tighten the bolt from the outside with a flathead screwdriver, and tighten it through and with the T-nut.
I think I will put some medium loctite under the t-nuts.
- Then add some deadener or foam or some seal, on top of the mdf ring and mount the speaker.
Is that... good enough? Is there a better way to do this that I'm not thinking of?
just use riv-nuts or clip-nuts, made for blind fastening. some window weld should hold the ring on there pretty good..... being 4x6, you could even do a steel or aluminum adapter plate, just using tin snips, etc. youll get some good overlapping reinforcement. watch for echoing, ressonance in those pillars.
Actually the pods do not impact the sound of tweeters at all, it's all about location, reflections and pods while great in some locations, can be...
698
Holefully he doesn’t hook batteries in series thinking it halves the voltage…..
29
It is a wives tale if the only evidence could be coincidental. I agree that vibration is bad for everything except women, but that doesn't mean...
32
6K
I would put two Eyelets on front and back close to the bottom of the enclosure with Toggles, rubber washers, and metal washer to seal the...
HardofWhoring
Phoenix, AZ
akheathen
