My Sub amp keeps blowing Fuses???
LowRydr
I have a 600w kenwood 2ch amp and every time I put power through it the fuses blow with in seconds! I had this amp in my other car and it was working fine, but since i took it out I hasn't worked. So far it has blown 8 fuses, two fuses each time I try to put some power through it. Has any one had this happen before? If so, what was the problem and how do I fix It?
I appreciate the help!
If it wasn't grounded properly how could that make a power surge like this?
I doubt that it would, maybe if it was very loose and continually became grounded and ungrounded, but usually the amp just wont turn on, or has lots of noise. Take it to a shop and have it tested out, I think its fried //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Just scored this on Marketplace and he threw in the DSP. Excited about going active with the amp. The DSP wasn’t the one I was ultimately looking...
9
577
Use any negative terminal or positive terminal slot out of the amplifier outputs or speaker outputs. Only one positive and one negative should be...
649
T-taps wiggle loose and give static when they do. Posi-taps are too fancy. I just peel a bit with a wire stripper and wrap the splice on that...
LowRydr
LowRydr
LOS ANGLES, CA
nosaj070
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
