Need some help picking out a sub and amp setup
Johnny121
So currently I'm looking to put a sub in my 350z, I came across a photo that shows how to make a sub box that fits perfect. It only provides about .64 cubic feet so finding a sub is hard, I found this skar sub (https://www.skaraudio.com/products/svr-8-inch-800-watt-max-power-car-subwoofer) which should be pretty good for the small size. However, I want to wire it up for 4ohms and finding an amp that provides 400rms at 4ohms has been hard. If anyone could help find a cheaper amp that could make this setup work that would be great, otherwise help me find another sub that works for small boxs. Thanks
Not a Skar fan but the Sundown E10 would work in .65 cubes sealed. Dayton HO 10 also does well in small boxes.
Why are you trying to wire up to 4 ohms?
The Taramps Bass 1200 2 ohm will do 600 rms at 4 ohms and is very small.
This is my first sub install and from what I researched 4 ohm offers more clarity and easier on the amp, at the sacrifice of loudness. For me this seemed to be the best option because I don't need anything crazy loud, but if 2ohm is better in your opinion I might have to do more research. Also thanks for recommending me some products because I'll i can find on Amazon is skar and kickers.
You will never hear the difference between 1-4 ohms. I would wire to 1 ohm and keep the gain down over being wired to 4 ohm with alot of gain to try and get enough power. Headroom in amps is always a good thing. I would get a d2 ohm E series subwoofer and a Taramps MD1200 personally.
Awesome thanks for the help! Also im curious to know why you don't like skar I usually heard good things about them.
Kevin the owner was once a member on here (Lambo911) and scammed alot of people. Why the nickname "Skam Audio". If you Google Skar Scam you can still find quite a bit on it. They lie about alot of their products specs. Alot of people also give Boss audio great reviews and we all know its straight garbage. :ROFLMAO:
That box is designed for 5/8" mdf. I would definitely glue and brad nail (1-1/4") that box together. I'm not a fan of screws in 5/8" mdf. It might be better to just switch to 3/4" mdf and keep the inside dimensions the same.
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
514
881
Johnny121
Johnny121
Wiscosnin
Bobbytwonames
just call me KeV
    Jun 2, 2024
just call me KeV
    Jun 2, 2024
