SomeGuyDude
It's been a while since I've done it, but here we go. My aim for the RE SEX15 was 4.0cu with a port at around 34Hz. Got 'em from the RE site
So here's what I did:
I took optimal dimensions as 16.5" tall and 30" wide. These are INTERNAL dimensions, judging by the numbers in the later steps, hence 16.5" so I can get it 18" tall total. Then a 16.5x3" port, which means a length of 21.15" according to WinISD.
From there it's adding up the displacement (17.25x3x29.19 for the port) 0.633 + 4 + 0.17 for the sub = 4.80cu, yes?
Now it's that fancy-dan formula for my mystery dimension: depth. Take our above numbers and slam them together (4.80*1728)/(16.5*30) = 16.75
So my internal numbers are LxWxH of 16.75x30x16.5 internal, and 18.25x31.5x18 external, correct?
Now, figuring out the dimensions of the WOOD will require a whole lot of sketching, but I think I can do that just fine. I just need to make sure I've got all my digits correct.
My final question: how does one factor in a bending vent? If it has to be 21" long and I've got an 18" deep box, that's an extra three inches. Do I just take the 21" piece of wood that would normally go straight, then just cut it and re-glue/screw it where it would need to be? Seems to me that would affect its effective length, but maybe not.
