actually isnt there another 1.5 inches of port length(half the width of the port) due to port end correction seeing as the port is on one of the enclosure wallsim pretty sure your port length would be 13.75 + .75 + 2.75 + .75 + 3. which would make it 21
im not sure i understand what you are saying. no i dont think there is another 1.5 inchesactually isnt there another 1.5 inches of port length(half the width of the port) due to port end correction seeing as the port is on one of the enclosure walls
I know what he means. Eons ago guys would talk about something that I -believe- was dubbed "port correction" where basically you'd consider another few inches (half the width of the vent) inside the box as part of the port in all calculations. I think it came about because someone did some really rudimentary physics and didn't understand exactly what he was doing, but it caught on. Don't think it's legitimate though.im not sure i understand what you are saying. no i dont think there is another 1.5 inches
Actually I got lazy and started using this thing: http://www.reaudio.com/speaker_box/LPort_Box_Calc.html
Since I'm looking to make a box for a T4, this actually made things easier because the Soundstream manual says don't even take sub displacement into account, so I can do things straight as it says.
if you increase the overall depth to 19.5 " you'll get 4.45 after port b-4 sub that's with a three inch prt idk if that port length is even valid just going off what you provided
hope this helped next time just post max dims and ask for suggestions plenty of ppl here will add their $0.02
i was under the impression that was what i provided ??It's been a while since I've done it, but here we go. My aim for the RE SEX15 was 4.0cu with a port at around 34Hz. Got 'em from the RE site
So here's what I did:
Then a 16.5x3" port, which means a length of 21.15" according to WinISD.
My final question: how does one factor in a bending vent? If it has to be 21"
So I was right about the term? And yeah, I figured if it's a factor, RE would have it already as part of its equations, and as for displacement Soundstream's instructions even say "4.0ft^3 (w/o sub displacement)" so apparently that's not even a factor to them.Here is a link that explain more what i was talking about http://www.caraudio.com/forum/showthread.php?t=357091 there are alot more posts here and there about it in alot of other threads aswell. Also im pretty sure if your using the re calculator it is already adding in the port correction, but dosnt take into account sub displacement.
sub displacement is always a factor. they must have figured the volume needed was 3. somethin net and with the added sub displacement came out for 4 cubes even or close to it to make it easy.So I was right about the term? And yeah, I figured if it's a factor, RE would have it already as part of its equations, and as for displacement Soundstream's instructions even say "4.0ft^3 (w/o sub displacement)" so apparently that's not even a factor to them.
They also mention fiberglass insulation, so I'll have to snag some of that.
Well yeah, that's what I mean. They have the numbers set so I don't have to worry about it on MY end. Which is convenient. I can just use round numbers.sub displacement is always a factor. they must have figured the volume needed was 3. somethin net and with the added sub displacement came out for 4 cubes even or close to it to make it easy.
1st questionWell yeah, that's what I mean. They have the numbers set so I don't have to worry about it on MY end. Which is convenient. I can just use round numbers.
So as it stands I'm looking at 16x16x38. Takes up the entire hatch from side to side but not too deep or tall. Question though: Is it possible to tune a box too low? If the manufacturer says 34Hz and I'm aiming at 33 or under, can that screw with the sub's potential somehow?
Second question: is 16" too short for a 15? I mean, the hole is 14.25" or something but am I cutting too close for actually mounting it? 17" wouldn't be a problem at all.
