Sub choice 150 db
i did 149 with 8 8's tuned to 52hz in 5 cubes in a trunk...that was on a HK4000D, i was happy with that...it would do 147.8 on music which was loud enough for me as it was louder than anything in trunk around at the time, i would squeeze 6 cubes in there at 45hz with 2 15's
and ur tuning is why......most for daily should be tuned to the 30's....
im trying to tune no higher then 35 if i cant change out the ports.38-45hz about the highest i think ill try
The box is the fun part..the funnest part.I can do a wall 2marrow and have it ready by friday 6 12's.
but i don't want to go that way. ill do somthing like 2 15's 1 18' in 6-7 cubes in a half wall that can be taken out .Once i see what the comps all about.
listen to what everyone is saying... you are not thinking about what it actually takes to hit that number out of a trunk, you will need new alt, battery's, full runs of cable, big 3.. the works.. your looking at a good $2500+
ahh...I'm hoping to be at least half way done by Sanjose. and if all goes well ill be fully juiced for the sac show.
i was going to try and keep it street stock for Sanjose dbdrag if not. street a/b
didn't know there was a modesto show(thats a 3rd chance ..if i like the comp scene im gonna try and be there
oh your talking meca. i do dbdrag bassrace. 30 seconds on music. yeah there is one in modesto on the 20th. i will be at the show in fortuna on the 23rd. so i wont be in san jose
Awsome. im having a issue with the clean versions of song rules-meca gotta hit the store and grab some slammers.
2 HDC3 15"s on about 2000 each, box tuned to about 38 will get you pretty close. the hdc's have a tight suspension so they can still dig down for the low notes even with that tuning
266
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
575
thanks DB, that definitely helps swallowing a $300 price tag 😂 these would essentially be running midbass for me too
12
607
lilboom
Car stereo for fun
lilboom
ca
Papermaker85
