This is going to sound like a worthless paradox..
But the only way to measure the impedance curve accurately is when you are playing that 50hz tone...
But if you are playing that tone.. then obviously it WILL play it...
So the question should be what will be impedance curve look like at 50hz?
And the question i have for you is, why do you need to know?
I am assuming you are wanting to know about 50hz because you will burp there.
Well.. burping is so quick when done properly that many competitors actually burp under 1ohm on 1ohm stable amps, actual impedance reading.
I'm not condoning the safetyness of it because it all depends on time and current\voltage..
But 0.6ohm is not drastic by any means.
A lot of us competitors may actually choose to run their equipment at that DCR load for daily.
Again, not saying you should because I know from this post you do not have the experience in knowing what to sense for but for burps, there should be no worry whatsoever as long as your amp is 1ohm stable.
The only way I could see a potential problem is if you were tuned to like 35hz and trying to burp at 80hz...
The closer your tuning and burp note is, the more likely your impedance curve at that point will be pretty high.
Example- I had a box 7yrs that was 8cuft for 1 15 on a 1500w amp.
Tuned to 29hz, burp at 31hz.
Wired at 0.7DCR
Burped at 4.2ohms
