What Sub Should I go with?
A box doesn’t do a lot with no subs in it... but if you can find one that does then send me the link lol
2PZwR6d
You’re right. However, if you buy another sub and put it in the same box your expectations will be crushed thinking there’s going to be a significant difference. The point being made is simply that the box will be key for better output even with the same sub you had. 👍🏼
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
Have you check to see if the prefab would fit...
13
It's fine to mount to the box. A lot of show car SPL setups have amps or other electronics mounted directly to the wood frame of the box or on an...
21
Not sure on your level of knowledge here. You can wire your sub up 2 different ways, resulting in 2 different resistance (ohm) values. Your amp...
31
4K
I have installed a alpine sub and amp, using a line output converter it all works but the bass stays steady and does not change with the volume...
Jason Taylor
Jason Taylor
youdoofus
    May 19, 2024
    May 19, 2024
