What Sub Should I go with?
A box doesn’t do a lot with no subs in it... but if you can find one that does then send me the link lol
2PZwR6d
You’re right. However, if you buy another sub and put it in the same box your expectations will be crushed thinking there’s going to be a significant difference. The point being made is simply that the box will be key for better output even with the same sub you had. 👍🏼
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
8
958
Have you check to see if the prefab would fit...
13
It's fine to mount to the box. A lot of show car SPL setups have amps or other electronics mounted directly to the wood frame of the box or on an...
21
3K
Not sure on your level of knowledge here. You can wire your sub up 2 different ways, resulting in 2 different resistance (ohm) values. Your amp...
31
4K
What is your budget? With being exposed to Rain.. I would recommend looking at a marine grade SAS Bazooka for the sub stage
257
Jason Taylor
CarAudio.com Newbie
Jason Taylor
youdoofus
Brendon Jenness
    May 8, 2024
Doxquzme
    May 8, 2024
