Dual battery voltage inconsistency while vehicle is on
  • 2
BCotrell
227
irvine, ca
So I was noticing my output has seemed a bit low lately and thought it’s time for a battery health check. Turns out my rear agm needed to be replaced....under warranty...which is good. However when I put the new battery in I’m seeing that I’m at 12.7 with the vehicle on... all while 14.2 at the front battery.
As I was reviewing my ground scenario i realized  that most of my grounds are body grounds and not frame grounds. Could this be the problem as to why I’m not getting 14 in the back or is 12.7 appropriate for the rear. It doesn’t right since the vehicle is on which to me means the alternator is doing the work. This is with the radio down to volume zero.
thanks
thanks
Yep, everything is in parallel and as such, under no load, they should all read equal voltages. Under load, maybe +-.1-.2Vdc is acceptable
Grounded my rear battery to front still big difference. Last thing to do is complete front battery to frame ground. After
That I’m out of ideas.
Whoa, that will be one skinny port. The width of the back wall ports will be 1.08" wide (27.5mm), but the front port will be shared by 2 subs so...
756
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
775
Recoil 2500.1 $179 2500 x 1 @ 1 ohm. Make sure subs are the dual 4 ohm version. If you don't want that much power, get the Recoil red1200.1 for 1...
874
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
BCotrell
BCotrell
irvine, ca
BCotrell
slater
    May 2, 2024
slater
    May 2, 2024
