How to wire 2 2-ohm dual-coil subwoofers to create a 2-ohm load?
  • 2
Blake Vandercar
22
So I can either wire each sub’s coils in parallel to create 1 ohm each, then wire the subs in series to create a total of 2 ohm load. OR I can wire each sub’s coils in series to create 4 ohms each, then wire the subs in parallel to create a total of 2 ohm load.
Does it matter which way I go with?
2 ohm final.
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
295
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
790
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
806
Blake Vandercar
Blake Vandercar
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
