Poor Wiring is now my problem HELP!!
  • 2
GageOtic
I bought a 2007 scion Tc that has an aftermarket Pioneer HU installed and I wanted to replace it with a newer Kenwood HU. The previous owner had payed for an install of an amp and 2 subs which sound great. When I swapped the 2 radios I am unable to get the amp and sub to power on. I am assuming that the two radio's pins are different and not allowing power to the amp. This wouldn't be a problem had the "professionals" not cut out the original harness and hand wired everything. Before I have to cut everything out and buy a new harness. Does anyone know of some kind of adapter with a female pioneer input to male kenwood that I can plug into the kenwood HU?
Anything is appreciated, just really don't want to have to re-wire everything...
The harness for a Pioneer and Kenwood are certainly different and there is no adapter between them. You will need to remove the Pioneer harness and wire-in the Kenwood. This is a typical effort for any HU swap. Be sure to individually insulate/tape each connection whether crimped or soldered. On the plus side, you have the pioneer harness for wire colors. Replacing them one-at-a-time will help you keep them straight.
Thank you, I have done many radio installs in the past. Was just wondering if anyone knew a quick work around since i don't have a real reason to so it beside bluetooth. Just didn't want to have to cut everything if anyone knew a different solution. Thanks again!
I don't even think you need to do that. You can use WiFi to connect wireless Android Auto but doing so kick out the units ability to self stream...
620
$500 is not unreasonable, but just know about alternator shopping: There are two numbers that matter: The amp output at or near idle (what's it...
791
Heres a clue, in the setup this was in, it was a previous car. And on the drivers side some of the newly installed wiring "caused" a bulge which...
201
GageOtic
GageOtic
indiana
GageOtic
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
