mtroupe
Junior Member
I have a Kenwood Double Din and I am using Bluetooth instead of CD music. Is it true that your amp gain settings are set higher when using Bluetooth than my normal Kenwood deck 5v output?
Any balancing should be done inside of the head unit or on the phone. There's no reason to adjust the amp gain settings when switching sources on the head unit. A lot of aftermarket units, at least on pioneer that I know of but it's probably common, have settings that adjust source volumes relative to each other to avoid blasting loud noise when you switch to the radio, etc.I have a Kenwood Double Din and I am using Bluetooth instead of CD music. Is it true that your amp gain settings are set higher when using Bluetooth than my normal Kenwood deck 5v output?
