Amp gain setting
  • 2
I have a Kenwood Double Din and I am using Bluetooth instead of CD music. Is it true that your amp gain settings are set higher when using Bluetooth than my normal Kenwood deck 5v output?
Any balancing should be done inside of the head unit or on the phone. There's no reason to adjust the amp gain settings when switching sources on the head unit. A lot of aftermarket units, at least on pioneer that I know of but it's probably common, have settings that adjust source volumes relative to each other to avoid blasting loud noise when you switch to the radio, etc.
The included image shows what feature you're looking for. It was snipped from this page: https://www.crutchfield.com/p_113DDX396/Kenwood-Excelon-DDX396.html assuming your head unit is quite similar to that one.
I hold firm on the deposit in all situations 😎
  • Locked
I dont see a Username and date on any of these pics that the FOR SALE Rules Should Apply. Are these pics off Ebay?? Place those with the pics so...
Voltage for the signal? What does that mean? Electricity isn't measured in purpose. Gain is a characteristic of a circuit. You aren't adjusting...
20
6K
mtroupe
mtroupe
Matteson,Il
Lasherž
    May 20, 2024
    May 20, 2024
