2 Channel amp using high level input but only 1 pair of speaker input
  • 2
mattlostatsea
Hi, Im trying to fit a 2 channel amp, Im using the high level input as i need to keep the standard head unit. Problem I have is that I only have 1 pair of high level input cables, the right rear speaker. The left rear speaker cable is not reachable unless i strip the rear car down.
So i have 2 speaker cables, left pos and neg. My amp has left and right high level input, shall i wire both left and rear channels high level inputs upto the speaker wire that I have?
Help
Thanks
Matt
It will work. Be aware that most music is recorded in stereo, so you may miss out on quite a bit of the program. It may eventually bother you to the point of re-doing the install. Now, if front speakers are more accesssible, use those.
419
497
871
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
903
Okay, I'll bite. If you're going to get rear speakers, get the same ones (model type, doesn't have to be the same size) that you have up front...
mattlostatsea
mattlostatsea
kent uk
