2 Channel amp using high level input but only 1 pair of speaker input
  • 2
mattlostatsea
CarAudio.com Newbie
Hi, Im trying to fit a 2 channel amp, Im using the high level input as i need to keep the standard head unit. Problem I have is that I only have 1 pair of high level input cables, the right rear speaker. The left rear speaker cable is not reachable unless i strip the rear car down.
So i have 2 speaker cables, left pos and neg. My amp has left and right high level input, shall i wire both left and rear channels high level inputs upto the speaker wire that I have?
Help
Thanks
Matt
It will work. Be aware that most music is recorded in stereo, so you may miss out on quite a bit of the program. It may eventually bother you to the point of re-doing the install. Now, if front speakers are more accesssible, use those.
6
118
Pretty much. It's just a nice kit. A solo rite Scarlett 2i2, XLR mic and a loop back cable are my next purchases so I can get accurate phase...
10
553
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
718
Okay, I'll bite. If you're going to get rear speakers, get the same ones (model type, doesn't have to be the same size) that you have up front...
I would keep the amp you have and keep the components. Place the components in some universal door pods, and look at getting a powered SAS 8"...
13
mattlostatsea
CarAudio.com Newbie
mattlostatsea
kent uk
1aespinoza
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
