Aftermarket stereo for 19 Civic
  • 6
You can run the SVC subs on the GM-DX871 at 1 Ohm, just lower the gain at the amp. The third sub is too different to run on the same amp as the...
No way to tell if the wiring is bastardized without looking for yourself. Wiring adapters are cheap enough at installer.com. That said there is...
710
High pitch whine is usually a grounding or interference issue or from using inexpensive signals cables run parallel to power/ground lines. Or, as...
Jlamb
Jlamb
Battle Creek, Michigan
Slo_Ride
metalheadjoe
    Jun 5, 2024
    Jun 5, 2024
