Mazda CX-5 New build
  • 2
lirancoh85
CarAudio.com Newbie
Hi,
I'm looking to upgrade my new 2021 Mazda CX-5 6 speakers version (non-Bose).
I was thinking about 6.5" Component at front and 6.5 Coxial/Mid Bass at the rear doors, connected to a 4 Channel Amp and JBL Basspro Hub at the spare tire ( I don't want to lose space at the boot).
Now, it's a bit tricky to know which speakers will fit at the doors as I couldn't find any documentation of depth compatibility for the Mazda CX-5 online. Does anyone know ?
Also, without knowing the exact size can you recommend any setup for a very clear & crisp sound without compromise ? originally I was thinking to go with:
Front Component:JL Audio C2-650C / Hertz Mille MPK 165.3 Pro / Focal PS165 FSE
Rear Coxial: JL Audio C2-650X / Kicker CSC65 / Cervin Wega V465
Amp: JL Audio JD 400/4 / Alpine X-A70F / Focal Impulse 4.320
Sub: JBL Bass Pro HUB 11"
Would love any input you guys have,
Thanks
Leo
That looks like it could be quite a nice sounding system. There might be some better subs than the JBL for what you want to do, and I'd definitely make sure you get a sub and box that matches the music you listen to and that's optimized for your vehicle. I think your mids and highs selection is nice. I would just say that maybe you'd want to significantly invest in the front doors/front seating sound stage with more sound than the rear, and maybe keep the rear simple and lower powered, like a filler stage. You could run a setup in the rear doors that has some heavy midbass, to make good sound for transitioning notes between the sub and midranges, where you have most of the the higher notes and vocals coming from the front. Just saying that as what I would do, based on how you appear to be going somewhat all in on a daily system. I would definitely have the front doors overpower the rear doors.
There's a lot of different types of enclosures you can to do to try and specifically try and get the sound you want from your sub. I would suggest doing a custom enclosure. You can make small subs really put out good volume across a wide bandwidth in the proper setup. Box makes all the difference with the sub stage, just FYI. I would also maybe deaden the vehicle some, but it depends on how well it's built from factory.
Thanks for the detailed reply.
I ended up getting the Alpine X-A70F and a cheaper rear speaker as the Ground Zero gzrf 6.5sq.
Im thinking now to invest a little bit more on the front speakers, people have been recommending the Morel Hybrid 602/62, also the Morel's are not as expensive here (Israel) like they are in Europe and the US as they are made in Israel.
WDYT ?
Kicker 46CSS654 CS Series 6-1/2" component speaker system chose these for the front chanel Kicker 46CSC654 CS Series 6-1/2" 2-way car speakers...
Well, I've owned probably over 100 different drivers in the last 40 years and almost every single speaker in the NVX line-up over the last 8...
16
934
https://www.youtube.com/@therealmatty_s/videos
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
I got to message a DD woofer builder a decent bit my last stent of box designing; they would send me designs to do for or with individual...
5
875
lirancoh85
CarAudio.com Newbie
lirancoh85
Tel aviv
Buck
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
