Aftermarket stereo for 19 Civic
  • 6
You can run the SVC subs on the GM-DX871 at 1 Ohm, just lower the gain at the amp. The third sub is too different to run on the same amp as the...
No way to tell if the wiring is bastardized without looking for yourself. Wiring adapters are cheap enough at installer.com. That said there is...
4
656
High pitch whine is usually a grounding or interference issue or from using inexpensive signals cables run parallel to power/ground lines. Or, as...
6
So you have your main power wire which feed the current it needs. Your original HU would have had it, and you probably connected your new HU to...
758
Jlamb
CarAudio.com Newbie
Jlamb
Battle Creek, Michigan
Slo_Ride
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
