Pro Audio Setup Q&A
  • 2
GoT_2B_BuMpN
Ok so I bought 8x SKAR Audio FSX 6.5 4 Ohm Mid Bass speakers and I have 4x SKAR Audio VX 3.5 Titanium Bullet Tweeters. I am planning to put 2x the 6.5s in each door and 2x the 3.5s somewhere up front, on either the A pillar or the door as well.
QUESTIONS: Do I need a crossover? Other than the one on head unit?
Can anyone recommend an amp for this setup? or at least what I will need for power?
How should I wire them?
What headunit? Going to need one with good active crossovers, a separate DSP, or separate crossover. I would do two 4 channel amps. 2 speakers per channel. 2 ohms each channel for mids. 1 tweeter per channel at 4 ohms each for the tweeters. With the 4 channels you will still have left/right stereo. If you went with two full range mono block amps you would lose out of left/right fade/balance but would be cheaper.
Check out the PRV 1200.4 for mids and 800x4 for tweeters.
What for crossovers?
Is American Bass better then Mmatts? Again I'm in love with quality and smoothness with alot of power and so far I'm Does the ABs have better...
Has anyone ever used one of these for a line level output from the head unit (aftermarket, not OEM)? I saw a past thread about changing jumpers on...
$2500usd for all three Shipping and PayPal fees extra I have a few BNIB pro series in stock I'm moving. These 3 listed is a full 3way system...
GoT_2B_BuMpN
GoT_2B_BuMpN
No Conway, New Hampshire
GoT_2B_BuMpN
    May 16, 2024
    May 16, 2024
