Help
So you have 2 two channel amps that you want to use as a single channel per amp? You also have 2 dual 2 Ohms subwoofers that you want to connect to each amp?
I have the 2 subs connected in series and parallel to each other and need to know the best way to connect them to both amps or should i wire the speaker to amps a different way.
Read the manual it should work okay that way. It says 500 watts but betting closer to 250-300 watts or so the XTR line is a decent line and do what they claim on dyno testing.
The cutting it off part is what I'm confused about now. The speakers in my car have two wires coming off of them but I would only have one wire on...
172
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
12
512
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
5
373
Agreed with this here. Since you have the unit pulled out of the car/dash...test it at your car battery directly for operation. very simple to do...
361
11
652
Dragonsbld
CarAudio.com Newbie
Dragonsbld
cobden illinois
audiobaun
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
