2005 Ford Focus ZX4 Glove box subwoofer complete. 4/27/2024
  • 6
View attachment 43172View attachment 43173View attachment 43174View attachment 43175
I have most of it done. I need to run the power cable to the alternator and another ground to the case. The techflex is 3/4". I'm getting the new Alt and battery for up front. I think the best thing to do is run an isolator up front on an agm battery and have the lithium in the back.
I think Ill try that TechFlex on my rebuild. I like that way it looks and what it offers for protecting the wiring from heat and corrosion
Might try using a Heat gun and a roller to heat that tape up and make it stick better? I use that method on all the deadner I usually put in. Never have an issue with anything coming loose. I even will hit Electrical tape to stick better if i use any of that. it may work for you
I will have to try that. I prepped it with isopropyl but still have issues. The weight of it just may be the problem.
I really think I'm losing my mind. I am cramming as many speakers as I can into this little thing. I wish my fab skills were better or that I had a glowforge but we are making due with what we have. My 15" midbass speakers have come from Newark.com. Why would you put a 15" midbass in a car. Well...because..reasons..
I decided in the beginning of this build I am not going to hold anything back and basically let my imagination unfulrl. Not really going to follow any rules; not really, just going to have some fun.
So onto the pictures. I have connected the base of bamboo dowels coated in the reinforced body filler to the housing for the AMT/Planars with stainless steel "L" brackets
They are pretty rough looking and I definitely dont want you to see them up close. lol Apparently I can't cut square lines and I need to dremel the absolute **** out of them. I will be hitting them with both long and short strand fiberglass to build them up. They each sit directly over a vent so I will need to mold them in a way that the air from the vent can hit the window.
SO it's been a minute since I have posted any updates. Life just went sideways for a while. But I am getting everything squared away. I have a few updates on what I have been up to. Let's focus on the "A" pillars first.
That's right baby. I trashed them. Basuuurrrrraaa. I had a few issues with them. One of the most significant reasons is due to the size. Each one was an absolute unit. And despite the layout I had some loss of sight of the passenger side. It was only the view of the side of the car but I didn't like the idea of that all.
So it was back to the drawing board again.... 3 times I built these things. So I tried a few other configurations. The baffle for the AMT's is way too big. (That's what she said....boom) I also thought about adding a 5" like those in the kicks. In the end I chose that less is more. You can see in the second pic that I have cut a 3/4" baffle for the planar tweeters and modified (cut hole) in the A pillar.
After building up a few layers of body filler and knocking them back I came up with a shape that wasn't horrible. Still cannot cut a square hole to save my life but it's all good in the hood.
Oh, right; the kicks were modified and rewrapped. Much happier how they turned out this time. Not perfect but an improvement for sure.
The carpet definitely needs to go. ..
SO.. returning to the A pillars. Funny story, I was attempting to wrap the pillars but there were so many compound angles that the suede was not having it. After about 45 minutes of struggling I decided to go to joann fabrics and see if I could find something that matched the suede but was of the 4 way stretch variety.
I ended up choosing a darker grey but when I brought it back to the car I had a pleasant revelation. The car interior is two tone with the top being darker and the bottom lighter. This turned out to be a win for me.
I'll take a few more pictures tomorrow for you guys to get a better example of the contrast but these few should give you a better example of what's happenin'.
It's not the best wrap. There are imperfections. I think I will go back to Joann's and get some rolled batting or thin jut to cover the pillars in and rewrap.
That's all I have for you homies. The front doors are next. I hope to have some more pics for you this weekend.
Well here it is the next weekend. I haven't gotten much done on the car. I'm doing some odds and ends. I did start the front doors but sadly all I have is a few teaser photos. I bounced back and forth on what I wanted to do about the front doors. I finally settled on an 8" B&C 8NDL51 and two of the sealed back 5." These are identical to the ones in the kicks. I still have four more of the Dayton midbass which I can use in the rear deck but that will most likely be after the first of the year.
I ended up making a cardboard template with some alignment markers and outlining on the door where I want to cut. I want to save some of it as I will make a lip that will cover the small bit of uncut trim at the bottom.
Here's a rough idea of what it will look like.
One of the drivers was dented but I bought extra and may end up using this in the rear deck where it won't be visible.
You may notice that it is a pro audio driver. Well, you would be right. I wanted a higher output midbass in the doors in front. It will be on 40 watts like all the other drivers and I will have the two 5" wired in parallel to 4 ohms.
I am using multiple midbass locations in this build. It may seem a little wack-a-doodle but it will work. We've got rain Sunday but we have a few days that are meant to be in the 50's so we should be able to get some **** done. Until then...
It's been a minute since I have made an update. Other things have been getting in the way. I have gotten a bit done today and I wanted to share a few pics of what I have been up to. I took the passenger door panel off first and got to modifying.
This is the door in it's present state. I am happy that the metal tape and deadener has held up through the weather. The only small issue was the neoprene that surrounded the door pull but I can zip tie that.
You can see from the pictures below where I initially cut the panel at the bottom. (map pocket) Notice that after shims were added the panel sits slightly above the panel. This is so when I build it out I can taper it so it slopes towards the panel.
You can see with the 8' driver resting in the baffle the depth isn't very bad at all. I was worried I was going to have to cut sheetmetal in the door but was pleasently surprised at it's depth.
There is a good deal of modification that needs to be done. I am going to use floral foam to build the panels. It will mean less fiberglass will be neccessary.
Cont...
Here a few more photos of the passenger door and a few of the brackets and hinges That I will use to mount the AMT's from the pillar. The paint is a BEHR paint and primer combo. I am working on a few things at once. So when fiberglass is curing I paint. When I am painting and letting it cure/dry I was working on staining the amp rack which I hope to show you tomorrow.
I have been working on the car the last few weeks despite the weather which is starting to turn around. I also got the the stomach flu that laid me low for 5 days. real horrorshow. It was like an Irish bar fight down there.
anywayy.. I have finished shaping the passenger side panel and am about to wrap it with suede. I'm also going to add a layer of adhesive backed acoustic foam to the rear of the door. The 8" will have a lot of output and I dont want any panel buzzes. There are still blemishes I need to deal with yet. Some filling putty was applied to a few areas.
I'll put a few more photos up tomorrow and an update on the rear deck which I have been building for 4 6.5" speakerers similar to the doors. Should come out pretty cool.
I'll need to swap out the hardware and I need to wire the door speakers up but this should give a pretty good example of what I'm after.
I made a rough cut on the rear deck. There is an oval shaped recess and this is what I will build out too using bamboo, modeling clay and reinforced fiberglass.
We're getting close boys. I think I may start wiring up the amprack tomorrow.
Can anyone in here participate in a short interview I am doing for school about the installation of a Kenwood DMX4070S in my 2005 Ford Expedition...
I had a '99 Chevy Venture with the 3.8 and buddy had one with the 3.4. Any of those engines including the 3.9 are known to leak coolant at the...
634
Then you need what I listed. You also need to find out if your Honda Element has an OEM amplifier or not. And if you have steering wheel controls...
941
https://www.sonicelectronix.com/ci95-2005-buick-lacrosse-wiring-harness-to-install-a-new-car-stereo.html?sort_order=price_asc lots of options...
526
just call me KeV
Junior Member
just call me KeV
chicago suburbs
    May 11, 2024
RedRyder18
    May 11, 2024
