Hi, I need help about speakers. BLAM, Focal, Hertz, Musway...
  • 2
LEOopasni2709
Croatia
Hello guys, I am soon changing my car and my front speakers need replacement because they are too small. I currently run Hertz Dieci DSK 130.3 Alpine bbx-t600 amp wich puts out 50w on 4ohm / 70w on 2 ohms and for sub i have Focal P30DB on Alpine MRV-M250 amp. I was looking at BLAM Relax series 165rx wich is rated 75W RMS at 2 ohm so I wonder if anyone has ever tried it. Other one I considered is Hertz Cento Pro CPK 165 wich is rated 105w at 4ohm. These two cost about 170euro in Croatia and that is max i would go becausse I dont see any point in getting more expensive speakers for this setup. So do you guys have any recomendations what should I put inside? Thanks
I've never heard of the BLAM brand but Hertz seems well regarded.
Almost all of the active members on this board are in the USA so we probably do not know what options you have there.
Yea, they are also not very known here so I tought maybe I will have luck here on forums. I looked at shops here and I think I will upgrade my amp and go with some Hertz speakers. We unfortunately fo not have a lot of options here...Hertz, Focal, Musway, DLS, Hifonics, Boston and few more
Out of the lot, if I had to buy sight unseen I'd lean towards Focal. Doesn't your local shop have a sound room where you can listen to them in person?
Unfortunately no, one local shop is pretty small and sells via internet and only does installs in shop and other shop is bigger but has no sound room. Unfortuantely we do not have dedicated store only for car audio :(
Will either shop do return/exchange if what you buy is just terrible? Here in USA I would tell someone to buy online from Crutchfield, they are very good about allowing you to return/exchange things if they don't work for you or you are unhappy.
Hopefully someone can help you who knows more about those brands, but keep in mind most of this is completely subjective and what may sound good to me may be not the kind of sound you prefer.
Yes, one shop is absolute best and last time they let me return it even when i mounted it on the car and tried it :)
Did you say you dropped it off at the autoshop? Well that's the problem. Not all all mechanics are made alike. Even if they are ASE certified...
that kind of describes the sound when the common is lost between a pair of channels. you get some lows and it plays the difference between right...
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
136
LEOopasni2709
LEOopasni2709
Croatia
LEOopasni2709
    May 19, 2024
    May 19, 2024
