New speakers again
  • 2
TommyGun41x
30
49319
I bought a set of infinity kappa’s awhile back and really liked them. 6x8 2 way 680.9cs. I’ve since blown the tweeters. I bought an oscope and set both amps with it. The kappa’s sounded great but 160 watts was too much. I’m replacing them with jbl stadium gto 860c. I’m curious how the sound will compare. The kappa’s were 4 ohm so I bridged my 4 channel amp. The jbl’s are 2.5 ohm so are only going to get 75 watts a side. I’m planning to just use the front channel on the amp. Us acoustics usx 4065. I might have to get a new amp. What do you guys think?
Run it!!! That amp is some clean underated power.Use It!! Its a Low TDH amplifier/pretty dammned clean amp. Put it back to work
I plan to, I’m just wondering about the power difference. 160 watts to maybe 70. I’m hoping it’ll still be strong enough for my sub stage.
If the JBLs have tweeters built in, disconnect two of the tweeters and the 4 Ohm tweeters will be their replacement. Then connect one combo on the...
68
Out of the amps you mentioned Kenwood 805 hands down best bang for the buck. You won't be able to tell any difference from 5x7 to 6.5. You may...
138
In the past 10/15 years. I feel like the best sounding/performing speakers Ive ever heard to date were some Hertz MLK & Mille series running off...
344
The Deaf bonce unit are not mdbass, they are midrange drivers. They will play pretty loud from 150 up. I don't support the company right now as...
483
TommyGun41x
TommyGun41x
TommyGun41x
metalheadjoe
    Jun 5, 2024
    Jun 5, 2024
