NEED AN AMP
  • 2
Whats your budget? Are you running a stock battery and alternator without doing the big 3? Do you have supply wring and ground wiring ran and set up already for the amplifier, and or plan on running a sub later? Stock HU or aftermarket? Just a couple questions I have for you
11
651
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
5
960
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
4
Thank you for your reply. What if I wire in series for 8 ohm load ? Sorry for my newbie questions, but wouldn't it have better sound quality...
Ridgeline14
Los Angeles, CA
audiobaun
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
