Installing a LOC on a Honda Pilot 2013 with factory Amp
AudioArchitech
I'm installing a Alpine 10' sub with a Old School Rockford Fosgate Punch 301M into my honda pilot 2013 but i ran into a problem. I wired up the Sub, Amp, checked all of the connections, everything is powering up and working. The problem is i dont hear any output being sent to the rockford amp. I tapped the LOC to the factory rear sub in the trunk space and have RCAs running to the amp. I dont understand what im doing wrong. Can someone give me some insight on things i did wrong or to check? The honda pilot also has a factory amp if that is important
There are a couple that SMD has tested, around $20.00 that should take the wattage from most any HU. If you are tapping into the speaker wires AFTER the OEM amplifier, depnding on the output, you may continue to pop anything you put in. This Kicker will take up to 55 watts.
Amazon product ASIN B00I4EF1BC
The safer bet is this NVX which will take 80W and it's only $16.99
Both units tested clean and distortion free to near or at rated input.
Amazon product ASIN B00H2XF64S
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
109
I would prob go and take it to a shop to someone that knows how to install, pay the $50-75-100 bucks so its done correctly.If you continue to do...
for my amp ground I have it to the paneling in my trunk, secured with a bolt and a nut. I sanded as much as I could, and I used a grind wheel on...
72
6K
AudioArchitech
AudioArchitech
San Diego
    May 16, 2024
    May 16, 2024
