EQ settings on Ipod touch vs Stereo
mjhubbard77
I have a car that I don't drive much. For over 10 years I've had the same Pioneer stereo, speakers, and amp and the only thing I listened to was the ipod classic hooked up through the back of the stereo.
I just replaced the stereo with a new Kenwood Excelon and swapped out the ipod classic for an ipod touch. The sound is a little different - not necessarily better or worse, just not quite what I've been used to for all these years. I prefer to get all of my eq and audio settings dialed in now and then not mess with it anymore.
How do the ipod eq settings and stereo eq settings interact with each other? Should I turn off the ipod eq (or leave it flat) and adjust the stereo eq? Or vice versa? Does anybody have any experience with what normally sounds better?
My recommendation is to leave the iPod EQ flat. You have a premium head unit with the eXcelon, and it has MUCH better internal components than the iPod. I would also avoid using more than 80% of the volume range on the iPod unless your adapter bypasses the volume controls (which is preferred). Rely on the eXcelon controls.
Good explanation, thanks.
id turn the iPod eq off/flat. fwiw, the ipods dont clip at full volume. i have had many and i have a scope
441
The intention of the eq is to create a flat curve if you have peaks and nulls. If you are competing for sq, try to get the sound as flat as...
434
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
You are going to need to beef up your sub stage in that vehicle to get that kind of bass response. A good pair of American Bass XFL 10s or 12s or...
891
mjhubbard77
mjhubbard77
Michigan
JohnPD
    May 11, 2024
RedRyder18
    May 11, 2024
