Amps on protect
sameboysamesame
My door speaker was cutting in and out for a few days. I found the issue. It was a loose rca wire. But now that I’ve plugged it back in, my interior amp and also subwoofer amp are both on protect. I have absolutely no audio whatsoever. I have no idea what caused this and don’t know how to fix it without buying new amps. I don’t want to run into the same issue if I spend money for new equipment. Can anyone help me with this fix? Thank you in advance
Where is the RCA in the chain? Maybe the RCA is actually no good or not grounding correctly? Sound's like you have a short or grounding issue somewhere.
Not sure If I can Help you fix the issue without being present.. But the first thing i would do is remove all RCAs and All speaker wires from the amplifiers in the OFF position, and see they they go out of protect when you turn them back on.
Try that First and let us know what happens.
155
417
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
sameboysamesame
sameboysamesame
Houston,Tx
    May 18, 2024
    May 16, 2024
