Amp Clip
22loweryak
CarAudio.com Newbie
Hey looking for some help. I amp running a 130amp alternator, with Skar Audio 0/1 Gauge kit to a Agm Power cell with a Taramps 5k to 2 Vxf 12's (1200RMS-3000PEAK) but if I barely even turn it up to where I can feel the bass the amp wants to clip needing suggestions on what my issue could be
What's the voltage at the amp?
Do this to set your gain
Just know that your head unit's rated preout voltage, might be below your max volume. So if you max out the volume to set your gain you might be clipping just from the head unit. A DD1 can figure that out, you can contact the manufacturer to try to find out, and if it's a Kenwood, the max rated voltage is probably 34 out of 35.
If you can do that video, then you can make it so the amp is not a variable. You can always adjust the head unit volume by one, and keep working it until you figure it right.
Pretty much. It's just a nice kit. A solo rite Scarlett 2i2, XLR mic and a loop back cable are my next purchases so I can get accurate phase...
10
302
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
273
Speaker ratings are generally a thermal/mechanical limitation of the drivers. Music is dynamic, not continuous. During quiet periods a song, you...
4
154
22loweryak
CarAudio.com Newbie
22loweryak
Danville Ky
Jimi77
SlugButter
    May 4, 2024
slater
    May 2, 2024
Latest topics
