COMPLETED SLAPZ oblivion subwoofers
slapzaudio
Pro Seller
Price
$$281
Condition (1 worst - 10 best)
Ambler pa
Use code BHOLB at slapzaudio.com
Get the SLAPZ audio oblivion subwoofers for under $300. Both 12’s and 15’s have a 2k rms, 4K max rating and sport a 4” voice coil.
Was Photo Included
  1. Yes
@Buck
Curious to what you think on these with the specs from their website. They kinda look familiar to me.
RMS ………...................2000 Watts
Peak …………..........…….4000 Watts
Impedance...................DVC 4 ohm (2 ohm parallel, 8 ohm series)
Voice Coil diameter …..4” 4 layer black coated
Winding depth..............2.36”
Pressed paper cone
High roll foam surround
270oz Y35 triple stack magnet
Double layer Nomex spider pack
Dual Tinsel leads
Oversized 6ga push terminals
Overall Diameter...........12.4”
Baffle cutout diameter..11.2”
FS …………..…..........…….37Hz
QTS............................. .66
QES............................. .75
QMS............................ 6.59
VAS.............................. 18.68L
Xmax........................... 29mm
Suggested ported box 2-2.5 cu/ft
Suggested port tuning 32-35Hz
@Buck
Pressed paper cone
Dual Tinsel leads
What’s the Bl, Re, Mms, Sd, etc? My bad with the edits, I think this is a vendor thread, and I’d rather comment outside of this thread on assessing these woofers using t/s alone.
Idk after looking at these and what numbers there are. Need to have those numbers buck mentioned as well. And I remembered why they look familiar. Look to be almost identical to the Audio Legion Maximus or w/e they were and those are only 1,200 RMS.
I'm betting @djdilliodon! knows exactly what plant they are from and everything.
Those black diamond dia 12's look like armada's...I really liked my armada 12's 🤔
I still have 8 of those Java 10s I picked up when they went on sale. (4) DVC2 ohm and (4) DVC4 ohm. Tried 2 dvc4 in an old ported enclosure and they sounded pretty decent for some low powered subs man. All I see on thyere site is a pair of Java 10s in a ported Enclosure for $99 Bucks. Not bad for a beginner or needing a little bass
I got my buddy one of those java 10's for his bday last year...it sounded pretty good sealed in his truck...wasn't crazy loud or anything but it was nice and clean sounding
If I didn't have my two 4500s already I would probably try the Creampie 7500/ Slapz 8k. :poop:
Lighten up man, it's all in good fun. Having more to go on than I want a sub that is less than 6" deep heps the forum narrow the focus. Why...
Adire Brahmas were incredible subs. One of the first subs that could really compete with the JL w7s. Super flat BL curve gave the subs a really...
Placed a pair in a an enclosure according to enclosure specs below on a Crescendo Skyway 3k and they seem to be doing very nice and really...
slapzaudio
Pro Seller
slapzaudio
ambler pa
djdilliodon!
    May 16, 2024
    May 16, 2024
