Bridged 4 channel memphis viv 400.4 for focal es 165 k fronts. Amp has switch for 2 or 4 I put it on 2 ran rca's from front to front on amp + and - I'm getting mono sound no balance .do I need to go from read Hu to rear amp with rca's for stereo .?
Usually amp's front RCAs are the universal input. What do you mean by "amp + and -"?Bridged 4 channel memphis viv 400.4 for focal es 165 k fronts. Amp has switch for 2 or 4 I put it on 2 ran rca's from front to front on amp + and - I'm getting mono sound no balance .do I need to go from read Hu to rear amp with rca's for stereo .?
Arent the speakers Rated for 4 ohms? Bridging that amp will throw him @ a 2 ohm load and could possibly damage the speakers eventually or blow some caps in the crossover section if not tuned properly and easy on the volume knob? Might be better to look for more power @4 ohms unless running Active for all 4 chsThat amp puts out 65x4 or 200 x 2 and he is running Focal 65ks. Bridged, no rear fill. Bridged gives the OP the most power. It is important to pay attention to the speaker connections as they are different and not something most people getting their feet wet are accustomed to seeing.
